2000 Nissan Xterra Engine Shuddering and Hesitating
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
2000 Nissan Xterra 6 cyl Four Wheel Drive Manual 170000 miles
The engine begins to shudder and try to cut off after driving 8 or 10 miles...I can keep it going for a while if I continue to rev it up, but if I really get on it it will stall out...is this the distributor?
If keeping the accelerator pressure on it runs, then it could be the idling system, spark plugs, coil packs or fuel injectors that need attention.
If it fails to respond at high speed or rpm while driving, it should be the fuel system, either the fuel filter is clogged, pump is weak or thr regulator is faulty.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
