Hi radiant777,
The immo sensor is installed at the ignition key and there is a chip inside your car key.
If you hace a spare key, use it and try to see if you can start.
If the immo is having problem, there would not be any gauge or meter indicator lights showing when turning ignition switch to on.
If you have the indicators working, then it should be electrical, either a faulty ignition switch, starter relay or gear shift inhibitor switch.
