Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
2000 Nissan Pathfinder 6 cyl Four Wheel Drive Automatic 115655 miles
WHEN IDLEING ENGINE OVERHEATS WHEN AIR CONDITIONING IS ENGAGED. WHEN MOVING OR AIR IS TURNED OFF IMMEDIATELY COOLS DOWN. RADIATOR AND THERMOSTAT ALL HOSES HAVE BEEN REPLACED. FAN SEEMS TO BE WORKING OK. DOES THE PATHFINDER HAVE ANY HISTORY OF THIS TYPE OF PROBLEM
Find a car repair manual for your Nissan Pathfinder Repair Question.
Posted at Sun Jun 22, 2008 10:43 am
By
blackop555,Certified 2CarPros Master Technician
when the ac is turned on the fan shoudl run faster OR the second fan if equipped should turn on! i would be checking for that first, if still has that problem could be a lean running condition or a cooling system in need of a flush.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
