Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Automobile Safety Inspection
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2001 Dodge Intrepid No ...
Auto Repair2000 Toyota Camry Ignition
Auto Repair1994 Chevy S-10 My Truc...
Auto Repair1996 Dodge Avenger Tran...
Auto Repair1996 Chevy S-10 Hard To...
Auto Repair1992 Honda Civic Radiat...
Auto Repair2003 Honda City Front Axle
Auto Repair More Repair Topics...
Free Car Repair Advice by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2000 Mitsubishi Galant
Goto page 1, 2  Next
Posted at Sat Oct 31, 2009 7:57 am
By jhorner, Have Donated
(7) Give Feedback | Votes: 0
Transmission problem
2000 Mitsubishi Galant 4 cyl Front Wheel Drive Automatic 101246 miles
Original problem - cooling tank in radiator busted and filled transmission with antifreeze. In result it took the transmission out. Since then I have replaced the transmission, radiator and lines. I installed Mitsubishi fluid and now when the trans. shifts from low gear it trips the check engine light and goes straight to third gear and stays there until you clear the code. Then it repeats the same. Check engine code says low gear not synchronized and the dealer says it was a bad transmission. Put another transmission with 40,000 miles in the car and it does the exact same thing. Where do I go from here?
Find a car repair manual for your Mitsubishi Galant Repair Question.
Posted at Sat Oct 31, 2009 9:37 am
By KHLow2008, Certified 2CarPros Technician
Reputation: 5023.5Reputation: 5023.5Reputation: 5023.5Reputation: 5023.5Reputation: 5023.5Reputation: 5023.5Reputation: 5023.5Reputation: 5023.5Reputation: 5023.5Reputation: 5023.5 (5023) Give Feedback | Votes: 68
Hi jhorner,
Thank you for the donation.
What was the exact trouble codes retrieved?
If the codes are similar, it could be caused by the TCM. Check all wiring connectors at trans for contaminations and poor connections.
The trans is going into limp mode because some sensors are not synchronised.
Was any sensor reused from the previous trans?
Posted at Sun Nov 01, 2009 6:36 pm
What was the exact trouble codes retrieved? 41 & 42
If the codes are similar, it could be caused by the TCM. Check all wiring connectors at trans for contaminations and poor connections. Checked all connections and they were ok. Where is the location of the TCM and is it combined with the ECM? The dealer said it only has one computer. Cleared codes drove car, got it to go to second gear and then it went to limp mode. Does this year of vehicle need a relearn?
The trans is going into limp mode because some sensors are not synchronised. How do you get the sensors to synchronise?
Was any sensor reused from the previous trans? No
Posted at Mon Nov 02, 2009 4:09 am
Code 41 and 42 indicates a likely fault with the trans. One of the clutches is slipping causing the sensors to have a variation in readings and out of sync.
Were both the trans showing the same trouble codes?
The PCM controls the engine and trans so is in one unit under the dash on passenger side.
Recheck the input and out put shaft sensor installation. Check if the terminals and location are the same as the original.
Some JDM trans wire connectors are reversely installed and would result in the sensors being wrongly connected.
Posted at Mon Nov 02, 2009 5:19 pm
Were both the trans showing the same trouble codes? YES
I RECHECKED THE SENSOR LOCATION AND THEY ARE THE SAME AS THE ORIGINAL. ONLY DIFFERENCE BETWEEN THE ORIG. TRANS AND THE OTHER TWO IS THE ORIG. HAS AN EXTERNAL FILTER THAT LOOKS LIKE AN OIL FILTER AND THE OTHER TWO DID NOT. IS IT POSSIBLE THAT THERE IS MORE THAN ONE TRANSMISSION FOR THIS VEHICLE? THERE WERE NO SHIFT PROBLEMS WITH THE ORIG. TRANSMISSION UNTIL THE ANTIFREEZE GOT IN THE TRANSMISSION. IS IT POSSIBLE THAT SOMETHING INTERNAL IN THE OTHER TWO TRANS. DIFFERENT THAN THE ORIG?
Posted at Mon Nov 02, 2009 7:42 pm
The one with external filter is a different model trans and is the newer type. If that is the case, the PCM does not match the trans.
You have the wrong type of trans installed.
There are many variations of trans and most of them are interchangeable where installation is concerned, they do not work.
Are the trans code punched on top of housing similar?
Posted at Tue Nov 03, 2009 9:11 am
The orig. had the filter on top of trans. Is that the only one that will work or is there another way to identify the trans. that I need?
Posted at Tue Nov 03, 2009 10:34 am
Sorry for the error.
Yours is a newer model and the only way to ensure you get the correct ttrans is to use the identification code punched on top of trans.
Number must be identical to be correct.
Posted at Tue Nov 03, 2009 11:40 am
Is there any way to reprogram the replacement trans. to make it work?
Posted at Wed Nov 04, 2009 7:36 am
There are no known programmable procedures.
PCM is not getting the correct signal as the gear ratios for the input and output shafts are different.
Either you get the correct trans or you would have to replace the PCM with one that is compatible.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
