Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Jeep Cherokee Viol...
Auto Repair1993 Jeep Cherokee 1993...
Auto Repair1994 Plymouth Voyager N...
Auto Repair1997 Ford F150 Help
Auto Repair1992 Acura Integra Blow...
Auto Repair2001 Ford Ranger 4 By 4
Auto Repair2000 Acura Integra
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Mitsubishi Galant Car is nearly overheating when drive
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Jul 02, 2008 6:21 pm
By mvs, Likes cars!
Give Feedback | Votes: 0
Engine Cooling problem
2000 Mitsubishi Galant 4 cyl Front Wheel Drive Automatic 61,000 miles
About 1 month ago, I had the timing belt replaced on my 2000 Mitsubishi Galant, as recommended by the manufacturer. The car seemed to be revving high, and after 2 trips back to the mechanic, things seemed normal. Two weeks have passed, and now the car is running very hot (temp. gage is very close to being in the red zone). The car was brought back in and the thermostat was changed and the radiator was flushed. The car was taken on the turnpike today and once again, the temperature was climbing near the red. HELP!!!!! I feel like a pest bringing the car back again.
Find a car repair manual for your Mitsubishi Galant Repair Question.
Posted at Sat Jul 05, 2008 7:40 am
By KHLow2008, Moderator
Reputation: 170Reputation: 170Reputation: 170Reputation: 170Reputation: 170Reputation: 170Reputation: 170Reputation: 170 (170) Give Feedback | Votes: 13
Hi mvs,
If the car has a problem bringing it back is not being a pest.
When does the overheating starts? High speed? City driving?
Are the fans working?
Is there any coolant leakage?
Is coolant level in radiator full?
Was the water pump replaced when timing belt was replaced?
Posted at Mon Jul 07, 2008 5:24 pm
By mvs, Likes cars!
KHLow2008 wrote:
Hi mvs,
When does the overheating starts? High speed? City driving? Overheating starts after being driven at high speeds - 30 -50 minutes after being on highway
Are the fans working? Yes, according to mechanic.
Is there any coolant leakage? No.
Is coolant level in radiator full? Yes - radiator was flushed after the new thermostat was installed
No, water pump wasn't replaced with the timing belt.
The car was checked again by the mechanic over the weekend, and they say everything is fine. They had it out on the highway, and nothing happened, but they didn't ride it long enough. Today, the car was driven on the highway and it was nearing red after 1 hour of driving.
Posted at Tue Jul 08, 2008 4:13 am
Hi mvs,
When the gauge is showing hot, are the fans working full time or they start and stop?
What did you do and how long did it take for the temp reading to go down?
Does the high temp occurs only at high speed driving?
Posted at Tue Jul 08, 2008 3:58 pm
By mvs, Likes cars!
KHLow2008 wrote:
Hi mvs,
Thanks KHLow. Not sure about the fans working full time or start/stop when it runs hot. I'll have to pay attention.
As soon as it started nearing the red, I shut off the AC and put the heat on full blast. It took approximately 10 mins for the temp needle to start going back down to where it should be. But even with the heat on the needle wasn't at the "normal" position. While it was better and away from the red, it was still running where I would consider it hotter than normal/usual.
Yes - the gauge seems to only creep toward the red when high speed driving. I can drive it around the city for awhile and it will remain pretty much normal. But 10-15 mins of driving on the highway at 75 mph and the needle quickly starts to rise. This never used to happen prior to having the timing belt changed.
Thanks again in advance for your help/suggestions.
Posted at Tue Jul 08, 2008 9:35 pm
Hi mvs,
If the overheating occurs only at high speed driving, the cooling system is inefficient, you need to check for,
1. Clogged radiator, hoses and passageway.
2. Thermostat unable to open fully.
3. Weak water pump or loose belting. Was water pump replaced same time as timing belt ?
4. Radiator coolant level.
Posted at Wed Jul 09, 2008 5:46 pm
By mvs, Likes cars!
Hi KHLow2008,
The water pump wasn't replaced when they changed the timing belt.
I dropped the car off at the Mitsubishi dealer, so hopefully they'll solve the problem and I can drive it on the highway.
Thanks for all your help and suggestions. I'll let you know what the outcome is!
KHLow2008 wrote:
Hi mvs,
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
