Auto Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
2000 Mercury Cougar 60mph+ vibration
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Mon Aug 25, 2008 1:46 pm |
By
tylermax,
Have Donated |
Give Feedback | Votes: 0 |
Tires and Wheels problem
2000 Mercury Cougar 6 cyl Front Wheel Drive Manual 88000 miles
2000 mercury cougar 4 wheel disc brakes (not sure if that is important) car had original 215/50/16 tires. had the car stored for about 6 months in 2007. when i got the car out of storage in december, it had a healthy vibration at about 50 plus mph. I just thought that the tires had flat spots. I switched out the rims and tires with aftermarket rims and tires 225/45/17. still getting the vibration, not as bad but still very very noticeable (and probably dangerous) and its still happening around 60 plus mph. ordered the wheel package online, and they were supposed to come already balanced. so after feeling the vibration, i had an alignment and balance at a local tire shop. thought it fixed it a little bit temporarily (maybe just psychologicial). but problem remains now for sure. could this really be a tire balance problem or something with the suspension, maybe? I don't want to have a blowout or something or damage the brand new tires. Also the car is pulling to the right.
| Find a
car repair manual for your Mercury Cougar Repair Question. |
Posted at Wed Aug 27, 2008 4:47 am |
By
tylermax,
Have Donated |
yes, I forgot to mention, the tires had nitrogen in them, but i removed that and replaced it with air and made sure all the tires had the exact same recommended tire pressure (40psi in this case) and that did not help. I had a shop check the all the front end components (yesterday), although I am not sure if they checked the camber, toe and caster. But anyways, they could not find anything. They said that they "think" its the aftermarket rims and tires (even though i explained to them that it was doing it with the stock wheels and tires). Also they said that they "think" also that it could be the aftermarket crossed-drilled and slotted rotors I have on there (even though they meet OEM spec, and do not cause any vibration upon braking). Needless to say, they did not help me much other than to tell me they are not sure what is causing the vibration. I have an appointment today to with a different, more reputable shop, that has a "on the car tire balance system" or something like that. When I called the shop to make the appointment for today, the guy said that he has never met a vibration problem that he could not fix. So hopefully he hasn't met his match his with my car...
Also, on a side note: I should have added the fuel stabilizer upon storing the car, because for about three weeks after I got it out of storage it was hiccuping and burping and even stalled a few times at idle, but after a few weeks, and then on after, it runs great.
| Find a
Posted at Wed Aug 27, 2008 6:16 pm |
By
sumitup,
Likes cars! |
(7) Give Feedback | Votes: 0 |
Tylermax......
keep me posted on your progress, I too am having the same problem but at 70mph. The shop cant seem to give me an answer.. I had tie rods, control arms new brakes, rotors and calipers. Still does it.
The shop didnt have a wheel balance machine so I had to get it done elsewhere and it still didnt work.
Thanks
Kevin
| Find a
Posted at Thu Aug 28, 2008 3:11 am |
By
tylermax,
Have Donated |
okay well I took it to a shop yesterday and they said that everything on my front end looks good except the drivers side control arms look pretty bad and the passengers side control arm is somewhat bad. He said he is "pretty darn positive" that this will fix my problem. I hope so because it's like $685 with parts and labor to fix both control arms in front. Could this be the possible cause? and is $685 a fair price? They said that they had to get those parts from the Mercury dealer because nobody else carried them, and they charge $75 an hour for labor, which is pretty reasonable in this area.
CarPros... please give a quick reply if possible before and let me know what you think before I make a $685 mistake! thank you.
| Find a
Posted at Fri Aug 29, 2008 3:03 am |
By
tylermax,
Have Donated |
If when you mean dragging, do you mean touching of the pads and rotors while not applied? I am pretty sure they are not touching, because I used to have a car that did touch once I got the brakes changed and I could definitely hear it while driving.
I don't think the rotors are warped because it does not shake when I apply the brakes. Would it still be possible to get a warped rotor that doesn't shimmy the car when I apply the brakes, but still cause vibration at interstate speeds? When you say bad rotor do you mean warped?
| Find a
Posted at Mon Sep 08, 2008 5:58 am |
By
tylermax,
Have Donated |
ok, I went ahead and paid to get the control arms fixed, and the car runs like a dream now! no vibration at all. The shop said the lower control arms experienced dryrotting, likely from sitting in storage for six months.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
