Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Jeep Cherokee Viol...
Auto Repair1993 Jeep Cherokee 1993...
Auto Repair1994 Plymouth Voyager N...
Auto Repair1997 Ford F150 Help
Auto Repair1992 Acura Integra Blow...
Auto Repair2001 Ford Ranger 4 By 4
Auto Repair2000 Acura Integra
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Mazda Protege car dies when warm
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Aug 28, 2008 11:34 pm
By kr4z33, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
2000 Mazda Protege 4 cyl Two Wheel Drive Manual 70000 miles
This car has had this problem pretty much since I got it ~1yr ago. it dies after it stays warm for a while, running the heater at full blast seems to extend the range a little bit, but it mekes me kind of uncomfortable...
The mass air flow sensor was covered by an extended warranty, and was supposedly failing (per the engine computer's codes), so I had Mazda replace it.
problem persisted
took it to a shop to diagnose, they said the downstream o2 sensor was faulty and the catalytic convertor needed to be replaced, projected cost was nearly $1000 (OMFG WTF??)
I replaced the o2 sensor
problem persisted
removed the catalyst from the catalytic convertor (I may put a cheaper one downstream later on...) catalyst was grey and melted, obviously shot.
car ran a little better, but still the problem persists...reset the computer, engine light stayed off untill the car sputtered to a pathetic death as I barely got it off the road into my driveway today.
Now, I ask would it help to put in a another new downstream o2 sensor, assuming the first one I put in got burned while living behind my shot catalytic convertor? any other areas to check on that could cause this kind of behaviour?
why would a faulty o2 sensor cause a car to die, seems like a flawed design. old cars didn't have these, it should not be essential for the car to run right? I thought o2 sensors existed to limit emissions and to maximize fuel economy. shouldn't the computer default to a less efficint operating mode instead of dieing all the time and leaving in the middle of the road waiting for the stupid thing to cool off so I can use it again?
Find a car repair manual for your Mazda Protege Repair Question.
Posted at Fri Aug 29, 2008 2:46 am
By mmprince4000, Moderator
Reputation: 72.6Reputation: 72.6Reputation: 72.6Reputation: 72.6 (73) Give Feedback | Votes: 4
The O2 sensors are key in adjusting air/fuel ratio for maximum effeciency.
If out of range they will usually default to a rich condition, which will eventually cause the convertor to overheat and melt.
You will have to replace the convertor and O2 sensor, bu you would also want to check the other sensors (scan tool in live data mode) to make sure they are within specs.
Also check fuel pressure, fuel pressure regulator (gasoline in the vacuum line). Make sure you are getting good spark.
The Mass Air Flow sensor was propably what caused the failure of the O2 sensors and convertor to fail, since it would default to a rich mixture if bad, causing the convertor to overheat and excessive backpressure causing the O2 sensor to fail.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
