Electrical problem
2000 Hyundai Accent 4 cyl Front Wheel Drive Automatic 129000 miles
Bought car recently. Wouldn't run at all untill I had the MAF changed. Runs good now but it wont pass smog and has trouble shifting. Error codes "PO123 TPS sensor A CKT high input" and a transmission code. The TPS is a easily replacable part and it looks as if the hack I bought it from already did. Isn't there a way to set/calibrate the TPS electronically? Which the hack probably didn't do.
Also may need a Cat but thats another future issue.
Doing my daughter a "favor"
Find a
repair manual for your Hyundai Accent Repair Question.
Posted at Fri May 02, 2008 11:14 am
By
Advertisment,
Find a
Posted at Fri May 02, 2008 11:52 am
By
merlin2021,Certified 2CarPros Master Technician
There are many TSB's on the automatic tranny in these, but to get you the right info I need the actual tranny code..TPS is not adjustable, you can only do a function check, here's how:
You might need to clear the codes with a scanner...
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
