Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Plymouth Voyager N...
Auto Repair1999 Jeep Cherokee Ther...
Auto Repair1987 Pontiac Trans Am T...
Auto Repair1990 Acura Integra Repl...
Auto Repair2005 Chrysler Town And C...
Auto Repair2003 Ford Focus Check E...
Auto Repair2002 Honda Civic Oil Dr...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Honda Passport Car "stumbling" at high speed
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Aug 29, 2008 10:53 pm
By Daveinsierras, Have Donated
(14) Give Feedback | Votes: 0
Engine Mechanical problem
2000 Honda Passport 6 cyl Four Wheel Drive Automatic 108500 miles
I have a 2000 Honda Passport 3.2 V6 4x4 auto transmission, 108500 miles. It has started to have a minor hesitation when I start to accelerate from a stop. This is more noticable with an aggressive start. It then seems to be okay as it accelerates untill it gets to 55 -60 mph. It is okay if I maintain the highway speed but if I try to accelerate say from 55- 65 it "stumbles' is the best way I can explain it. Only recent work was a flush of the transmission which I do about ervery 25,000 miles. This hesitation or stumble seems to be in the engine and not in the transmission, but I could be wrong. What do you think?
Find a car repair manual for your Honda Passport Repair Question.
Posted at Sat Aug 30, 2008 1:46 am
By rasmataz, Certified 2CarPros Master Technician
Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3Reputation: 990.3 (990) Give Feedback | Votes: 75
Possible Causes of Engine Hesitation or Stumble:
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
