Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1985 Honda Civic
Auto Repair1999 Jeep Cherokee Loss...
Auto Repair1994 Other Hyundai Model...
Auto Repair2001 Oldsmobile Alero W...
Auto Repair2002 Saturn Sc2 Slave C...
Auto Repair1991 Other Hyundai Model...
Auto Repair1995 Honda Accord How T...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Honda Odyssey how to?
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Jun 09, 2008 10:52 pm
By 1deadelvis, New to the forum
Give Feedback | Votes: 0
Air Conditioning problem
2000 Honda Odyssey 6 cyl Two Wheel Drive Automatic 130000 miles
I just had a AC prob. It stopped cooling and starts to overheat if the AC is lturned on. On popping hood, the passenger's side fan is NOT working (it used to when AC was on). I went foolishly into trying to change the fan out without checking if it actually ran (any info on how to check either with Vmeter or jumping the 12 V into the connector)? Also, I found the relay (I think) for the AC under the cruise control ... any way to check that? Assuming it is the fan, how do you get the fool thing off without taking off the radiator. I originally thought that the thermostat was sticking causing the AC to stay off ... changed thermostat, flushed and filled the radiator. I spent about 2 hours pulling stuff off trying to get the fan off and about an hour putting it all back with no success. It has now become a issue of price (sighs heavily). Any help much appreciated.
Find a car repair manual for your Honda Odyssey Repair Question.
By Advertisment,
Posted at Fri Jun 13, 2008 7:53 am
By KHLow2008, Moderator
Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6Reputation: 218.6 (219) Give Feedback | Votes: 12
Hi 1deadelvis,
To remove the radiator fan you need to remove the fan and shroud assy by
1. removing the upper 2 bolts.
2. loosening lower 2 pcs bolts.
3. disconnecting upper radiator hose.
4. disconnecting fan wire socket.
and you can take the assy out.
To test fan motor operations, check for blown fuse. You can apply battery voltage by looping at the relay. DO NOT try to use direct battery voltage as any internal shorting of fan motor can cause injury.
To test relay, you need to apply battery voltage to coil circuit and test for contuinity at the other two terminals.
Posted at Sun Jun 15, 2008 8:31 pm
KHLow2008 wrote:
Hi 1deadelvis,
Many thanks ... with that info .. I pulled the motor fan and with a little sweat and cussin ... was able to yank and replace the bad unit ... many thanks from Graceland ... Elvis sends.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
