Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1991 Chevy Lumina Rough...
Auto Repair1997 Ford Crown Victoria...
Auto Repair1996 Honda Accord Clutc...
Auto RepairDaewoo Leganza 2002 With...
Auto Repair1994 Toyota Camry Check...
Auto Repair1994 Toyota Pickup Sudd...
Auto Repair2002 Daewoo Leganza Sta...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Honda Civic overheating
Welcome to our question and answer forum. We answer over 6,000 free and donated auto repair questions every month. All you have to do to ask a question is to signup to our forum.
Asking a question is free of charge and your question will be answered by one of our non-certified forum users for free. You can however elect to donate to make sure your question gets an guaranteed and professional answer by one of our many 2carpros certified repair technicians.
Questions with donations are answered as promptly as possible. Due to the nature of car repair problems, some take longer to solve than others. We are confident that you will be better informed regarding your problem and will have an good idea of what direction your repair needs to go after we have answered it. If you have donated and were unsatisfied with our effort we will gladly return your donation. We help thousands of people every month and want to help you too. Sometimes it requires some dialog between our technicians and you to get to the bottom of your problem. 100% of the donation is awarded to the technicians helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat Jul 05, 2008 7:43 pm
By matthao, Have Donated
Give Feedback | Votes: 0
Engine Cooling problem
2000 Honda Civic 4 cyl Front Wheel Drive Manual 150000 miles
My 2000 civic 1.6L. Is over heating. Recentinly i was driving it and the upper hose blew. At first it started backfiring then i put it in -N- so i can get to the side of the road. So far i have changed all the hoses. Checked if there was any leaks around the radiator and back side of motor. nothing. Now that i drive it doesnt overheat unless im at high rpm for a long period of time. Especially when i turn my AC on. When i turn off then car. I check for leaks again cause my reserver keeps getting lower. I can also smell burned cooliant, but i see nothing leaking. I dont know what it could be except for the water pump and head gasket. Is there a way i can check these or do i
have a malfuntion else where. I also replaced the
thermostate. This is the First motor problem I have had with this car.
Find a car repair manual for your Honda Civic Repair Question.
By Advertisment,
Posted at Sat Jul 05, 2008 8:34 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8Reputation: 952.8 (953) Give Feedback | Votes: 75
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump
Posted at Sat Jul 05, 2008 9:19 pm
how do i do a block and pressure test and a gas
analyzer test. I plan on doing a whole tune up my car with changing the timing belts and pullys. with adjusting the valve springs. I would like to
figure out the main problem so it wont be so costly on my half.
Posted at Sat Jul 05, 2008 9:27 pm
Test the water pump do below-
One way to test for a bad water pump is to squeeze the upper radiator hose when the engine is hot and idling. Careful, because the hose will be HOT! If you do not feel much coolant circulating through the hose when you rev the engine, the pump may be bad. The other cause might be a bad thermostat that is not opening properly (remove and inspect the thermostat), or a clogged radiator.
Posted at Sat Jul 05, 2008 10:10 pm
when i do that it doesnt feel full like half empty.
compaired to the bottom hose feels full. If I take the timing belt cover off will i see any anti-freeze leaking from
the water pump.Lastly what is another way of checking
the head gasket? Because when i drive the car after shutting it. A strong FUME comes from the driver side after opening the hood? anymore ideas would be helpful.
I have maintained this motor to the tee. So i would like to keep it a little longer
Posted at Sun Jul 06, 2008 1:04 am
By KHLow2008, Moderator
Reputation: 216.2Reputation: 216.2Reputation: 216.2Reputation: 216.2Reputation: 216.2Reputation: 216.2Reputation: 216.2Reputation: 216.2Reputation: 216.2Reputation: 216.2Reputation: 216.2 (216) Give Feedback | Votes: 12
Hi matthao,
If the reserve tank keeps depleting, there should be a leakage somewhere.
Look for coolant stain marks when the engine is partially warm atter cooling down.
Check if the radiator drain cork O ring is worn.
Posted at Sun Jul 06, 2008 2:01 pm
Remove all the sparkplugs and inspect for coolant in the cylinders unable to get a chec bloc tester its a fluid that's changes color when exhaust gas is present in the cooling system or a cooling system pressure tester
Posted at Mon Jul 14, 2008 12:29 am
after flushing my coolant from my car, and changing
all my heater hoses, my car wont start. I sprayed the engine bay afterward. I know i didnt get the distributer
wet cause i opened the cap n checked. Everytime i crank
it over it makes a loud humming noise like vroomp, kinda
of like a hollow noise. Please help
Posted at Mon Jul 14, 2008 2:46 am
Do below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
