Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
2000 Honda Accord 6 cyl Two Wheel Drive Automatic 100000 miles
Hello, I'm trying to help my daughter fix a problem on her car that is complicated by what appears to be some modifications that were done to it. The car was bought in 2000 new, but it appears to have an engine electrical system from a 2007, it has the individual coils on each spark plug and a "V-TEC" marking on it. The check engine light came on after the engine suddenly started running rough during a local trip. The OBD2 card reader called out cylinder 1 as misfiring so I swapped the coil with another one and the problem followed it, I replaced the bad coil and the car improved some, now it has a #6 cylinider misfire code coming up first and then the other cylinders fail also, even code P1399 comes up. I've put fuel cleaner in it just in case she got some bad fuel, no help there. Is there anything else electrical that could be causing the problem? Is it possible the timing chain is worn and causing this?
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
