Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Air Conditioning problem
2000 GMC Yukon V8 Four Wheel Drive Automatic 140000 miles
I have a 2000 yukon 4x4 and need to replace my A/C compressor. My question is do I need to also replace the condensor and completely flush the system. And can the exsisting condensor, oil and freon by reused.
why are you replacing the compressor? if it isw leaking at the seal in the middle or front then you can use the old condenser. if the compressor blew up internally then you will have to evacuate all the old freon and oil out of the system and most likely atleast replace the orifice tube(filter) and recharge with new oil and refrigerent
There are no leaks that i know of I am looking at replacing the A/C compressor becuase the belt tensioner bounces loudly when AC is on and while accellorating. I have already realced the belt tensinor and belt and the noise it still there. It stills blows out cold air in the fornt and and not so cold in the back of the yukon.
im not sure this is going to fix your problem but you would not need to replace condensor or anything else and you could reuse old freon if you have a ac recycle machine. i would check the pressures and see if maybe you have a higher than normal high side pressure. this is most commonly caused by a weak fan clutch. the higher than normal pressure would cause more stress on ac compressor. a fan clutch that is bad wont necessarily make your engine coolant temp any higher so dont be deceived.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
