2000 GMC Jimmy my JIMMY will not start no matter what
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
2000 GMC Jimmy 6 cyl Four Wheel Drive Automatic
I have a 2000 GMC JIMMY about 3 months ago as i was driving to work in the morning i stopped on a red light when the light turned green i notice that my truck had turned off. I tried to turn it on but it only made the noise when its gonna start but it didnt. I ended up getting it towed to my house. i have checked for it to have spark and it has good spark i aslo checked for the fuel pump pressure and it has 55-60 psi. i also checked for it to have any codes but nothing came up. I put a new battery, and a new starter. Even if i prime it it wont start so is been 3 months and i havent been able to get my truck started not even one time.
Have you done a relearn on the pass-key?
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
