Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2000 GMC Jimmy 4 cyl Four Wheel Drive Automatic 96000 miles
My engine light comes on and then goes of with in hours or maybe the next day. I ran a dignostic test and it came back with the codes of p0101 p0174 p0171. What does that mean and I just had the fuel pump replaced last week. I have put so much money into this SUV than any other car I have owned. Its Killing me.
P0101 - Mass air flow sensor circuit range problem.
P0171 - System too lean Bank 1
P0174 - System too lean Bank 2
Check the Mass Air flow sensor connection and test the sensor as well. You can look at the data live if your scan tool allows it.
A bad MAF can cause all three codes.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
