Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Jeep Cherokee Viol...
Auto Repair1993 Jeep Cherokee 1993...
Auto Repair1994 Plymouth Voyager N...
Auto Repair1997 Ford F150 Help
Auto Repair1992 Acura Integra Blow...
Auto Repair2001 Ford Ranger 4 By 4
Auto Repair2000 Acura Integra
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Ford Windstar abs
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Oct 11, 2008 8:39 am
By joey729, Likes cars!
Give Feedback | Votes: 0
Brakes problem
2000 Ford Windstar 6 cyl Two Wheel Drive Automatic 100,00 miles
Is there anyway to check abs codes and clear than with out a scanner? also how to check wheel sensors using a ohm/volt meter?
Find a car repair manual for your Ford Windstar Repair Question.
Posted at Sat Oct 11, 2008 9:11 am
By racefan966, Moderator
Reputation: 75Reputation: 75Reputation: 75Reputation: 75 (75) Give Feedback | Votes: 3
Yes you can read and clear code for your abs with a scan tool. However you need a get one that will do it. Not all scanners will. So talk to you parts pro at you local parts store and let them know what you need the scanner to do. As for the wheel speed sensors I will have to look in my books at home and find out so I will get back to you.
Posted at Sat Oct 11, 2008 9:16 am
I asked if THERE IS A WAY WITHOUT USING A SCANNER TO CHECK AND CLEAR THE ABS CODES???????????? like jumping the wires?
Posted at Sat Oct 11, 2008 7:14 pm
In short no there is no other way on an OBD II computer system. Sorry you will need a scanner or have a shop scan it.
Posted at Mon Oct 13, 2008 8:40 am
how to check wheel sensors using a ohm/volt meter? I asked last week you never replied
Posted at Mon Oct 13, 2008 6:15 pm
I am trying to find the answer for you on this one. I have many books to look through and mitchel 1 (which costs me money) to look at and sometimes it just takes a bit of digging. I have not forgot you so don't worry just need a bit more time.
Posted at Mon Oct 13, 2008 6:17 pm
ok
Posted at Mon Oct 13, 2008 6:58 pm
Ok now the speed sensors generate an electromagnetic field so with the sensor ring which interrupts the the field as each wheel turns it will generate a low voltage analog (continuous) signal. This signal rises and falls in proportion to the wheel rotation speed. So if you where to back probe the wire that sends the signal (which I do not have any information on the wire colors anywhere that I can find looked) and turned on the key engine off and spun the wheel then the sensor would increase voltage the faster the wheel spun and less the slower it spun. I hope this answers you question if you need anything else just ask ok.
Posted at Tue Oct 14, 2008 4:01 am
By Bad74Charger, Likes cars!
Yes you can check your wheel sensors with a ohm meter.. Unplug from the harness near each wheel put a probe on each prong. They should read around 200 ohms if they are good
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
