Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Other Rover Models
Auto Repair1995 Buick Lesabre Comp...
Auto Repair1997 Eagle Talon Engine...
Auto Repair1994 Bmw 520 Serpentine...
Auto Repair1997 Isuzu Hombre
Auto Repair1993 Lincoln Town Car O...
Auto Repair1998 Ford Fiesta Repeaters
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Ford Mustang will not start
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sun Nov 30, 2008 7:35 am
By johnnyredneck, Likes cars!
Give Feedback | Votes: 0
Electrical problem
2000 Ford Mustang V8 Two Wheel Drive Manual 65000 miles
hooked up autoxray OBD11 no codes . pulled a plug coil wire off verified pulsing volts at 5 to 7, thought maybe gas gauge was off ,added 3 gallons fesh fuel ...same-same turns over all day , no lite -off...if the pump goes out woudnt i get a code showing no fuel delivery...did not notice any noise from tank, but then again never have before either.also did quick reset on car alarm / car computer reset no luck.PLEASE HELP...im an airplane mechanic and most of those systems are easier than a cars
Find a car repair manual for your Ford Mustang Repair Question.
Posted at Sun Nov 30, 2008 2:07 pm
By jdl123, Tech level 5
Reputation: 30.2Reputation: 30.2 (30) Give Feedback | Votes: 1
Can you check fuel pressure? If you think it is a fuel issue, check the bump switch. The owners manual says it is in the trunk on the left side, behind the trunk lining.
If that is a two wire connector, back probe the circuits with the engine cranking, both wires should be hot. Let us know what you find.
Were you using a scanner or code reader?
Posted at Sun Nov 30, 2008 4:14 pm
the car has sat for the last 2 months.ran perfect......wouldnt this switch need setting off.....also auto xray handheld used with no codes produced with a complete scan.will ck pwr at switch.12 volts at switch...this has to be the quietest electric pump ive ever NOT heard...will check that pump harness in AM.....should be 12 volts at the connection if so i know the pump has taken a dump.....THANX for the help...i will post what fix was .
Posted at Mon Dec 01, 2008 6:48 am
You could try reseting the bump switch. Also, I thought that might be the easiest place to start checking for voltage at the rear. Have a helper crank the engine.
If this vehicle has electronic returnless fuel system, there should be a fuel pressure PID on the scanner.
Posted at Mon Dec 01, 2008 8:08 am
got 12 volts at switch . doesnt look like its tripped...next is the harness for the fuel pump. thers a q/d aft of the tank , i will check for voltage there...any info on pump changes if thats the culprit......internal or external
Posted at Mon Dec 01, 2008 8:54 am
I wouldn't replace anything, without checking fuel pressure. I asked about that in the first post. My hearing is no good, I can't listen for the pump. I have to check fuel pressure and amp draw for the pump.
I just wanted to add, the voltage and ground for the fuel pump motor comes through the pump driver module. You have to have both voltage and ground or the pump motor won't run. I believe the ground is a duty cycle, switched on and off. If there is something wrong with the system, a code should have set. Whether it will or not is a different story.
Posted at Tue Dec 02, 2008 7:07 am
have 12 volts at pump disconnect just aft of tank, also fwd rh fuel rail has pressure valve like a valve core of a tire..........no pressure at all........scanned until blue in the face ...........nocodes and scan successful message....no stored codes nothing
Posted at Tue Dec 02, 2008 7:23 am
is there a relay for the pump or the sending unit...im buying a book today for sure..........called just to see a shop charge on pump changeout-$700 that aint happening
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
