Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1993 Ford Explorer Need...
Auto Repair1995 Ford Mondeo Heatin...
Auto Repair2002 Chrysler Van Dash L...
Auto Repair2003 Cadillac Escalade ...
Auto Repair1998 Saab 9-5 Erratic H...
Auto Repair2000 Dodge Van Shifting...
Auto Repair1992 Other Ford Models W...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Ford F350
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Oct 04, 2008 2:37 pm
By zetamoon, New to the forum
Give Feedback | Votes: 0
Heater problem
2000 Ford F350 V8 Four Wheel Drive Automatic 200,00 miles
My heater fan only works on high. Also squeals every once in awhile when turned on. My question is how do I replace it. Is it done from the engine compartment or the under the dash. Does the dash have to be removed?
Find a car repair manual for your Ford F350 Repair Question.
Posted at Sat Oct 04, 2008 2:57 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9Reputation: 634.9 (635) Give Feedback | Votes: 51
HEATER SYSTEMS - F250-F350 SUPER DUTY -2000 Ford Pickup F350 Super Duty
Page 1 of 1
TEST C: BLOWER MOTOR INOPERATIVE IN LOW
1.Disconnect blower motor resistor 4-pin harness connector C169. Turn ignition switch to RUN position. Place function selector switch to FLOOR position. Measure voltage between ground and blower motor resistor harness connector C169 terminal No. 1 (Orange/Black wire). See Fig. 4 . If more than 10 volts exists, go to next step. If 10 volts or less exists, repair open in Orange/Black wire between blower motor and blower motor resistor. See WIRING DIAGRAMS . Retest system. 2.Turn ignition off. Measure resistance of Black wire between ground and blower motor resistor harness connector C169. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open or high resistance in Black wire. Retest system. 3.Place blower switch in medium-low position. Measure resistance between ground and blower motor resistor harness connector C169 terminal No. 3 (Light Green/White wire). If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, go to step 6 . 4.Place blower switch in medium-high position. Measure resistance between ground and blower motor resistor harness connector C169 (Yellow/Red wire). If resistance is less than 5 ohms, replace blower motor resistor. Retest system. If resistance is 5 ohms or more, go to next step. 5.Disconnect blower motor switch 4-pin harness connector C260. Measure resistance of Yellow/Red wire between blower motor switch harness connector C260 terminal No. 3 and blower motor resistor harness connector C169 terminal No. 2. See Fig. 3 and Fig. 4 . If resistance is less than 5 ohms, replace blower motor switch. Retest system. If resistance is 5 ohms or more, repair open or high resistance in Yellow/Red wire. See WIRING DIAGRAMS . Retest system. 6.Disconnect blower motor switch 4-pin harness connector C169. Measure resistance of Light Green/White wire between blower motor switch harness connector C260 terminal No. 4 and blower motor resistor harness connector C169 terminal No. 3. If resistance is less than 5 ohms, replace blower motor switch. If resistance is 5 ohms or more, repair open or high resistance in Light Green/White wire. See WIRING DIAGRAMS . Retest system.
Fig. 4: Identifying Blower Motor Resistor 4-Pin Harness Connector C169 Terminals
Courtesy of FORD MOTOR CO.
© 2007 Mitchell Repair Information Co., LLC.
http://www.ondemand5.com/mric/common/asp/printart.aspx
10/4/2008
It is probably a bad blower resistor, but if the fan is noisy, it may need replacement as well. Both are under the hood, look for #1, thats the resistor.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
