Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2003 Cadillac Cts Clutc...
Auto Repair2004 Ford F250 2004 Kin...
Auto Repair2001 Dodge Caravan Driv...
Auto Repair1999 Ford Explorer Oil ...
Auto Repair2002 Jaguar Xk8 How To ...
Auto Repair1997 Jeep Wrangler Time...
Auto Repair1994 Ford Ranger Timing...
Auto Repair More Repair Topics...
Car Repair Forum - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
2000 Ford F350 Brakes Locking up
Posted at Thu Sep 24, 2009 6:10 pm
By Cmsalady, Have Donated
Give Feedback | Votes: 0
Brakes problem
2000 Ford F350 Two Wheel Drive Manual 120000 miles
4 yrs. ago the front brakes locked up. They were cherry red, hot and literally smoking. This resulted in the installation of new rotors, new calipers, new brake pads, new brake hoses, all new brake fluid, new seals and repack the bearings, etc.
Than in March of 2008 I had brake problems again which resluted in 2 new brake rotors, all new brakes pads, repacking the hubs and new seals.
The first brake job was wround $1,000 and the second one was approx. $500.00.
At 151,000 miles (fall 2007) I had two new tires installed on the front and new two tires on the rear. I kept the best tires from the old tires and installed them on the rear inside of the dual wheels.
At 174,000 miles I purchased 2 more tires, installed them on the front and placed other two on the rear.
All total, the rear tires have about 23,000 miles; the front tires are brand new.
Just two weeks ago I was driving my truck and I noticed that the truck pulled to the left when braking and pulled to the right when driving. The front end wouldstart shaking so badly that I could hardly hang onto the wheel.
I went back to where I had the tires installed and had them check for balancing and a defective tire. Everything checked out. I drove about 20 miles and found the tires to be extremely hot and the rims would have blistered your hands! I took it to a mechanic and they told me that the caliper is frozen up on the right side, the pads are totally worn out and that they need to replace the rotors and brake lines and so forth.
So for the third time I have same thing ocurring again - this time only on the right front (although I expect it's just a matter of time before the left side fails as well). My quote is again, around $500.00 but only for the one side! This quote is for new rotor, calipers, repacking and so forth.
My question is this - before I spend good money after bad (Obviously as this is occuring again!) - what is causing this brake failure? What are the mechanics missing? something is being missed or else this would not keep ocurring.
My truck is a F350 Heavy Duty with a diesel engine, manual transmission, crew cab, long bed and has about 174,000 miles. It is driven for pleasure (on week ends) and I do use it to pull my horse trailer. As you can see, I have only put 23,000 miles on the truck since March of 2007 therefore it would not be excessive mileage and/or wear.
Right now my turck is sitting until I can find out the cause. No one seems to have a single clue. HELP!
Find a car repair manual for your Ford F350 Repair Question.
Posted at Fri Sep 25, 2009 4:55 am
By Service Writer, Certified 2CarPros Master Technician
Reputation: 123.6 (124) Give Feedback | Votes: 92
There is a problem with aftermarket pads and rotors with the f series. Apearently the Motorcraft pad composition often allieviates this.
Make sure the rear are working good and are fully adjusted.
BTW, Check the radius arm bushings.
Posted at Sat Sep 26, 2009 7:36 am
I'm sorry but this still doesn not answer my question or explain why the it keeps reocurring.
Posted at Sun Sep 27, 2009 5:22 am
Cmsalady wrote:
Brakes problem
HELP!
My apologies, I'll try to be more descriptive.
In 2005 your complete brake job did not include a rear brake adjustment. I assume these are rear drum brakes not rear disc brakes. "Make sure the rear are working good and are fully adjusted". IF the rears are ajusted it will help to give a better braking ratio t6hat will place more of the braking load to the rear so that the front brakes will have to do less work. The more work the front brakes have to do and the rotors overheat (sometimes accompanied by a pulsating feeling when braking
http://www.youtube.com/watch?v=_DFXaJ7Mw84&feature=related ),
the brake fluid may boil causing the caliper to engage and locking up.
I would be surprised if the calipers were new. More likley remanufactured. Typically they have a lifetime warranty on them. Before you can verify the cause, the parts obviously need to be replaced (use the motorcraft as I had mentioned).
BTW, what is the real current miliage? Can't be 120,000. Are the replacement calipers being lubed correct and with a good grease?
It wouldn't surprise me if they needed cleaning and lubing every 6000 miles in your case. Since the truck does a fair amount of setting, the odds are greater that the slides are more apt to corrode, the
Pads tend to not move back well, rotors tend to pit. Any of these can snowball into multiple part replacement.
I just replaced pads and rotors on truck that someone else did and they lasted 4 months because of poor installation.
A suspension problem such as the radius arm bushings for example may be weak and causing an abnormal movement affecting the caliper.
Any divoted type wear on the caliper bracket can cause the pad to become fixed and ineffective.
At what mileage were they done at in 2005?
How often were they looked at between those two miliages?
And then what mileage the next time?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
