Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Mazda Protege Roug...
Auto Repair1994 Dodge Intrepid Slu...
Auto Repair1990 Subaru Legacy Over...
Auto Repair2000 Infiniti G20 Do I ...
Auto Repair1991 Oldsmobile Cutlass ...
Auto Repair1996 Dodge Caravan
Auto Repair1987 Jeep Wrangler What...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Ford F350 auto 4x4
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Dec 02, 2008 11:23 am
By bobb stache, New to the forum
Give Feedback | Votes: 0
Transmission problem
2000 Ford F350 V8 Four Wheel Drive Automatic 111000 miles
my truck will not go in 4 wheel drive when the hubs are in auto position but will go in when i lock the hubs.the truck was in the ford dealer 2 years ago for this but there is no way I am going yo keep feeding incompetent repair men at my local dealer. is there something wrong with the truck,should I be using 4x4 every month.The truck isnt used much lately because of fuel prices,thsanks.
Find a car repair manual for your Ford F350 Repair Question.
Posted at Tue Dec 02, 2008 4:13 pm
By Dave H, Moderator
Reputation: 98Reputation: 98Reputation: 98Reputation: 98Reputation: 98 (98) Give Feedback | Votes: 5
4X4 WHEEL HUB NON-ENGAGEMENT/DISENGAGEMENT
TECHNICAL SERVICE BULLETIN
Reference Number(s): 03-14-3, Date of Issue: July 21, 2003
FORD:2000-2003 EXCURSION, SUPER DUTY F SERIES
Related Ref Number(s): 03-14-3
ARTICLE BEGINNING
DESCRIPTION
SUSPENSION - 4X4 WHEEL HUB NON-ENGAGEMENT/DISENGAGEMENT
AXLE - 4X4 WHEEL HUB NON-ENGAGEMENT/DISENGAGEMENT
ISSUE
Some 2000-2003 F-250/350 and Excursion 4X4 equipped vehicles may experience a condition where the front hubs will not engage or disengage properly. It is possible that the vacuum necessary to operate the hub is being restricted.
ACTION
Insure that the flow of vacuum is not being restricted through the hub. Perform Workshop Manual diagnosis per Section 308-07-A Pin Point Test G. If no problems are found in Pin Point Test G, perform the following procedure to relieve restriction in the vacuum path through the wheel end.
SERVICE PROCEDURE
Remove both wheel hub assemblies (See WHEEL HUB removal procedure under Section 204-01B: FRONT SUSPENSION).
Remove thrust washer located between the wheel hub assembly and the axle constant shaft (This gray plastic thrust washer is approximately 2 3/4" OD, and has four slots on the back side).
NOTE:KNUCKLE SEAL DOES NOT NEED TO BE REPLACED FOR THIS PROCEDURE.
File four (4) 1/8" to 1/4" "KEYWAYS" into the inside diameter of the thrust washer (Fig. 1 ).
NOTE:THE THRUST WASHER REQUIRES ONLY A LIGHT FILM OF GREASE. REMOVE ANY EXCESSIVE GREASE FROM WASHER, AND CAVITY BEFORE INSTALLATION.
NOTE:THE ADDITION OF THE KEYWAYS AND THE REMOVAL OF EXCESSIVE GREASE WILL ALLOW VACUUM TO PASS, UNRESTRICTED, FROM THE KNUCKLE, THROUGH THE HUB, AND TO THE HUB LOCK.
Reassemble wheel end per Workshop Manual Section 204-01B.
NOTE:DURING RE-ASSEMBLY, REPLACE YELLOW BEARING O-RING WITH PART NUMBER F81Z-4A322-AA. REPLACE HUBLOCK O-RING WITH PART NUMBER F81Z-1K106-AA. THE O-RINGS ARE CRUCIAL FOR PROPER VACUUM SEQUENCE OPERATION AND FUNCTION OF THE HUBLOCK.
PARTS INFORMATION
PARTS INFORMATION
Part NumberPart Name
F81Z-4A322-AAO-Ring - Bearing
F81Z-1K106-AAO-Ring - Hublock
WARRANTY INFORMATION
WARRANTY STATUS: Information Only.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
