Transmission problem
2000 Ford F250 V8 Two Wheel Drive Automatic 160000 miles
2000 f250 transmission codes po713 transmission fluid temperature sensor circuit high,po715 input transmission speed sensor circut malfuction,po717input turpine speed sensor has no signal,po720 output speed sensor circut maslfuction,po722 output speed sensor has no signaland the overdrive light flashes on the shifter.been dealing with this problem after the tran pump was rebuilt have allready checked the wiring harness for faults any suggestions thanks chris
