Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Suspension problem
2000 Ford Explorer 6 cyl Four Wheel Drive Automatic 114500 miles
can i change the shocks from underneath, orwill i need to go under the hood, and inside the cargo area
do you have a strut model? if so you can take out the assembly but you wont be replacing the shock unless you have the proper tools and a spring compressor.
it unbolts from the top under the engine compartment, and under, BEHIND the tire.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
