Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
unfortunately hard to diagnose without more info but ill take a shot at it. One question i have is has the timing belt ever been changed? If not you might have broken the timing belt which in turn smacks the open valves on the pistons causing severe damage to the head of the engine. The fluid is possibly the damage caused by the valves hitting the pistons could have cracked the head. An easy way to check is look at the timing cover there will be a small push in plug that you can remove at the top front of the cover. Use a flashlight and look at the gear in the cover and have someone turn the engine over and see if that gear is turning. If not then the timing belt has broken and you have suffered major engine damage. Neons have a no tolerance engine and when this happens you can kiss the engine goodbye.Hope this helps you find the problem unfortunately I cant give you good news. MORT
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
