Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Volkswagen Golf Wi...
Auto Repair2001 Ford Escort Epc Co...
Auto Repair2000 Peugeot 206 High F...
Auto Repair1998 Ford Escort
Auto Repair1997 Ford Taurus Wiper ...
Auto Repair1998 Renault Scenic C.v...
Auto Repair2000 Subaru Outback Dam...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Dodge Neon Did I kill the PCM
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat May 10, 2008 12:02 pm
By culthuu, Have Donated
Give Feedback | Votes: 0
Computer problem
2000 Dodge Neon 4 cyl Front Wheel Drive Automatic 127000 miles
I’m having a really bad day and I’m not sure why. Maybe someone with better knowledge then me can help. I have two 2000 Neons. 1 is an ES with all the toys and the other is a bare bones SE. Both have automatic. I took the ES to the dealer to reprogram the keyless entry fob I bought. They did the job OK but the car died a half mile from the dealership. I had it towed home and I’ve been troubleshooting it for two days. It cranks fine. The timing belt seems to be OK because the valves move when it cranks. It has gas. I checked the pressure and it’s OK. I checked the ignition module and it’s OK. So I thought maybe the PCM was bad and that’s where I screwed up. I took the PCM out of the other Neon and tried it in the ES. Nothing. But when I put it back into the original car the engine would start but it would die almost immediately. I fiddled around with it starting and stalling and then suddenly it wouldn’t crank at all. The battery was OK because the lights were bright but when I turn the key the headlights don’t dim and I hear nothing. So I got the bright idea of putting the PCM from the ES into the other car. It did exactly the same thing. It cranked fine and started but died immediately. It did this seven or eight times and then it refused to crank just like the other one.
I know now you have to match up the PCMs or have them programmed with the serial number but can you kill one if you don’t? I hate to think I’ve killed 2 of the darn things through my own stupidity. Thus the cause of my really bad day. The only codes I’m getting are 1684 and once I got a 1193. Please, I’m tearing my hair and contemplating buying any other car besides a Neon.
Find a car repair manual for your Dodge Neon Repair Question.
By Advertisment,
Posted at Sun May 11, 2008 9:24 pm
By mhpautos, Certified 2CarPros Master Technician
Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1Reputation: 461.1 (461) Give Feedback | Votes: 11
Hi there,
Thank you for the donation.
You should not be trying non conforming ECU's I would have the original ECU bench tested for a fault, there may be a system on the engine which has spiked the both ECU's so just bolting in another could get very expensive. Start with a known ECU, and if your has a fault, you will know where to start looking be for re fitting. Start here.
Mark (mhpautos)
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
