MANUAL A/C-HEATER SYSTEMS -2000 Dodge Intrepid ES
Page 1 of 1
Removal & Installation
1.Disconnect and isolate negative battery cable remote terminal, located on right strut tower. Remove left and right underpanel silencer/ducts and floor console. Remove center floor heat adapter duct and rear seat heat forward adapter duct. Loosen center support bracket and pry rearward to access actuator. 2.Locate mode door actuator on lower left side of A/C-heater assembly. See Fig. . Remove actuator screws and pull actuator straight down. Note shaft key position for installation. Disconnect actuator connector. To install, reverse removal procedure. When installing actuator, shaft must be reinstalled in original position.
© 2007 Mitchell Repair Information Co., LLC
7/29/2008
