Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1994 Ford Mondeo
Auto Repair1993 Ford Explorer Need...
Auto Repair1995 Ford Mondeo Heatin...
Auto Repair2002 Chrysler Van Dash L...
Auto Repair2003 Cadillac Escalade ...
Auto Repair1998 Saab 9-5 Erratic H...
Auto Repair2000 Dodge Van Shifting...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Daewoo Leganza Crank positioning sensor problem...
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Wed Oct 08, 2008 6:54 am
By spazdacamper, New to the forum
Give Feedback | Votes: 0
Computer problem
2000 Daewoo Leganza 4 cyl Front Wheel Drive Manual
Hi. I have a 2000, Daewoo, Leganza, with a 2.2L DOHC, manual front wheel drive transmission. I had a head gasket leak so I replaced it got every thing hooked back up properly. I have had 3 ASE certified tech check out my work and timing from the crank to the cams and all agree that is dead on. We checked and double checked all the wiring harnesses, grounds, and vacume/fule lines every thing is hooked up properly. But when we tri to start the car it acts like its trying to start and if you go wide open throttle the engine will start for like 2 seconds and backfire out the intake manifold. The engine is showing all the common signs of crossed wires but we have checked the wiring on the plug order as well. So we looked on our online data base and found two pages one saying the crank sensor will auto pick up and know when the firs piston is at top and ready to fire the second page says you need a $1,000 scan tool especially designed for Daewoo. It says the scan tool has a setting to reset the timing on the ignition coils and resync it with the pistons firing order. We have tried a tech 2 from GM and the car is not supported on our scan tool. So I was wondering if any one has any good ideas or knows how to get around this problem without a scan tool or maybe a way to trick the computer.
Thanks Jake
Find a car repair manual for your Daewoo Leganza Repair Question.
Posted at Sun Oct 19, 2008 5:09 pm
By YoBobYO, Have Donated
Doesn't look like anyone wants to touch this one. But I'll give it a try. I've replaced a couple of head gaskets already on these cars, and so far I haven't had any problem where the computer lost time or something. That just doesn't sound right.
If you have the wire set right and the timing mark are on the money,, then there is only a couple of thing that would cause the back fire. 1) You have a bent valve. Or 2) you didn't installed the cam gears right. You have the intake and exhaust switched. I'm not sure if this would cause any perminent damage. It would just open the wrong set of valve at the wrong time. You'll have to remove the bolts and washer holding the cam gears, and make sure you have the intake to the left, (towards the back fire wall) and the exhaust to the right (front of the car) The cams and the gears are the same. It's just on how you install and set the gears. The cam gear has a notch to set it as the intake or exhaust. Make sure these are installed right.
It's the only thing I can think that could of gone wrong.
good luck!!
Robert
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
