2000 Daewoo Leganza Replaced timing belt, car turns over bu
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
2000 Daewoo Leganza 4 cyl Front Wheel Drive Automatic 63000 miles
So i bought this car and needed to replace an idler pulley, replaced the pulley and made sure there was no valve damage as the timing belt never snapped. replaced the timing belt and put back in time. when trying to start the car, it turns over but does not fire. I bought some car starter fluid and sprayed it into the throttle body and got it to almost fire. After attempting 3 times or so i noticed a little smoke coming from the timing belt. It appears that oil is escaping from the intake cam gear, dont know why or how it would leak from there. Any assistance would be much appreciated, just trying to see this baby purr. Thanks
The cams have seals so one is faulty, as for the no start, i would start with having a scan done to check for any codes, and i would be re checking the valve timing and compressions, check for spark injection pulse and fuel pressure, start here.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
