Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
2000 Chrysler Grand Voyager 6 cyl Two Wheel Drive Automatic 91000 miles
The parking brake light keeps lighting up while driving. The parking brake is not on, but the light keeps lighting up and then it stops. It doesn't remain on it just goes on for a second or 2 and then off. What could this be from? Does it need brake fluid?
Find a car repair manual for your Chrysler Grand Voyager Repair Question.
Ok it could need fluid I would check that first but it could also be letting you now that there is a problem with the abs system too. Does the little quotation mark light up with it? Get back to me and we will go from there.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
