Disconnect electrical harness to the distributor. Check power to the harness. If there is power, check coil primary resistance between the 2 pins on the distributor. Resistance should be between 0.6 - 0.8 Ohms. Then, measure secondary resistance between the coil tower to both pins, of course one at a time. Resistance should be between 12 - 18 kOhms. If numbers aren't within specs, replace distributor assembly.
