Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
2000 Chrysler 300 6 cyl Four Wheel Drive Automatic 106,00 miles
hi i have a couple of question i have a chysler 300m 2000 with 106.640 miles on it every morning when i turn my car on it smell like gas by the gas tank i had it check out but they couldnt find the problem i am very concern because i have a 2yr old daughter who inhaleing it can you tell me wht might it be? also my check engine light is on i had it scanned it say purge system flow low they checked the purge solenoid and it was ok and they checked the vaccum sorce and condtion of canister and lines was ok what can be the problem
sometimes, when the gas cap is not completely tight , the system cannot create a complete vacuum. make sure your cap is tight, i mean you need to here it click like its being stripped, or your cap could just be no good. try that. then have your engine light erased at autozone(for free). and let me know what happens
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
