Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
2000 Chevy Monte Carlo Floating Fuel Gage
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Oct 07, 2008 9:38 pm |
By
police4,
New to the forum |
Give Feedback | Votes: 0 |
I have a 02 Monte Carlo, I had the same problem with my gas guage. I used some fuel cleaner that I got from the auto store and I kept filling my gas tank up all the time and soon I had to drive all the gas out til the gage had nowhere to go but to the E. and the gas light came on to let me know it was low on fuel and "knock on wood" that solved the problem. Hopefully, I don't have that problem anymore. Try that.
| Find a
car repair manual for your Chevy Monte Carlo Repair Question. |
Posted at Wed Oct 08, 2008 5:34 am |
By
hillre,
Likes cars! |
(30) Give Feedback | Votes: 0 |
Hello and thanks for responding! I was at a local Auto Zone one day and they suggested some sort of fuel additive (can't remember the name of it, looks like gas). The idea is to add about 3-4 ounces of it each fill up. This seems to work at first but i still have a floating gage. Can you tell me the name of the cleaner that you used? Afterwards, i will compare it to the one i purchased at Auto Zone. My low fuel light is working! The only catch to that is if you happen to dose off a few seconds, you will not see it illuminate for it only stays on for a little while. Isn't that odd. I would think that the low fuel light would stay on until you add more fuel to the tank.
Thanks, hope to hear back from you soon.
| police4 wrote: | | I have a 02 Monte Carlo, I had the same problem with my gas guage. I used some fuel cleaner that I got from the auto store and I kept filling my gas tank up all the time and soon I had to drive all the gas out til the gage had nowhere to go but to the E. and the gas light came on to let me know it was low on fuel and "knock on wood" that solved the problem. Hopefully, I don't have that problem anymore. Try that. |
| Find a
Posted at Wed Oct 08, 2008 5:37 am |
By
hillre,
Likes cars! |
Hello and thanks for responding! I don't know a lot about fuel systems. Is the fuel level sensor the same thing as the fuel sending unit? If so, is it normal for one to go bad at 76,000 miles? Can the sensor be replaced via taking out the rear seat OR does the fuel tank has to be removed? Thanks!
Hope to hear back from you soon.
| rhall77 wrote: | | you need a fuel level sensor. it is located in the tank |
| Find a
Posted at Wed Oct 08, 2008 9:26 am |
By
hillre,
Likes cars! |
| hillre wrote: | Hello and thanks for responding! I don't know a lot about fuel systems. Is the fuel level sensor the same thing as the fuel sending unit? If so, is it normal for one to go bad at 76,000 miles? Can the sensor be replaced via taking out the rear seat OR does the fuel tank has to be removed? Thanks!
I will read my Haynes manual to see how difficult this job is. Otherwise, I will have to take it to a local shop
which is the last thing i want to do.
| Find a
Posted at Wed Oct 08, 2008 10:15 am |
By
hillre,
Likes cars! |
| hillre wrote: | | hillre wrote: | Hello and thanks for responding! I don't know a lot about fuel systems. Is the fuel level sensor the same thing as the fuel sending unit? If so, is it normal for one to go bad at 76,000 miles? Can the sensor be replaced via taking out the rear seat OR does the fuel tank has to be removed? Thanks!
This may be a dumb question. If the fuel level sensor is bad, shouldn't my "Check Engine Light" (MIL Lamp) be illuminated? I thought all sensors are monitored by the OBD II system. Thanks again!
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
