Auto Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
2000 Chevy Impala
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Oct 28, 2008 4:52 pm |
By
20impala00,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic 128000 miles
my wife was driving home car sputtered for a second then shut off, vehicle starts but will not stay on, unless you give it some gas, if you manage to get it running it runs rough. my guess is the fuel filter. vehicle has almost new battery, recent oil, also radiato flush, and trans flush with 10k miles. any advice is greatly appriciated.
| Find a
car repair manual for your Chevy Impala Repair Question. |
Posted at Sat Nov 08, 2008 4:11 pm |
By
20impala00,
Likes cars! |
i have replaced all 3 ignition coils, spak plugs and wires, and now the fuel filter. car turns on but starts to run rough skanner code p0172 : system to rich(bank 1). checked under the hood because car shut off on its own plug wire #1,#3, and #5 are hot to the touch, #3 more than the rest, and #2,#4, and #6 are normal. what can i do to correct this.
| Find a
Posted at Thu Nov 13, 2008 5:49 pm |
By
20impala00,
Likes cars! |
decided to change fuel pressure regulator but still not resolved, check engine light came on, scanned, code is P0300 (random/ multiple cylinder misfire detected.
| Find a
Posted at Thu Nov 20, 2008 8:45 am |
By
20impala00,
Likes cars! |
tried all possible options with no luck, finally took to repair shop had diagnostic test, result was bad mass air flow sensor. this was a learning experience for me hopefully for you as well. thank you for your insight on this problem.
| Find a
Posted at Sun Dec 07, 2008 4:55 pm |
By
chevy bound,
New to the forum |
before I trade my car in - was your eventual fix expensive?
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
