Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Dodge Van Shifting...
Auto Repair1992 Other Ford Models W...
Auto Repair1998 Chevy Truck Heating
Auto Repair2005 Chevy Silverado Ba...
Auto Repair1998 Dodge Stratus R&r ...
Auto Repair2002 Chevy Blazer
Auto Repair1998 Dodge Neon Cold St...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Chevy Impala Funny starts
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Nov 21, 2008 3:48 am
By cman_02, New to the forum
Give Feedback | Votes: 0
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic 106000 miles
About a year ago, when I went to start my Impala it would not start. The radio came on, all the lights were on, and everything else electronic worked strong. It would not *click* like it was trying to turn over. So I asked a friend to come and look at it. He did and I looked dumb because he got in and it turned right over. It went through the winter with no problems at all. Then, about 2 weeks ago, same situation. My friend gave me some tips on trying to start it, like turning it on and shifting out of park and back into park. So I tried this. Nothing. So I repeated a few more times with similar results. I got a ride to work that day. The next morning I went out to see if I needed another ride to work and sure enough, it fired right up without anything else being done to it from the previous day. Does my car just have an attitude problem some days or what?? And the battery was only a year old before, making it 2 years old now. Any thoughts would be appreciated.
Find a car repair manual for your Chevy Impala Repair Question.
Posted at Fri Nov 21, 2008 6:30 am
By renaudTN, Tech level 4
Reputation: 22.1 (22) Give Feedback | Votes: 1
Hi there,
Although an intermittent problem with your ignition switch, or safety switch, or battery is not out of the question, I think your car is having the same attitude problem as many (many, many) other cars equiped with PASSLOCK (theft deterrent system).
Is your security light on when that happen? (blinking maybe?)
In a lot of cases, when your car doesn't start, you can usually wait 10 minutes, and it will start right up.
You can find a lot of posts about this issue online. I suggest you do some research about this before you go to a chevy dealer. A dealer would likely diagnose a bad BCM, or bad ignition switch, bad passlock sensor, or bad starter, etc, etc, and leave you with a much lighter wallet if you know what I mean.
They are ways to actually trick the passlock system without changing all kind of parts and spending mucho dinero…
Basically, when you put your key in the ignition and turn it, it sends a low voltage signal to your BCM (body control module) that ‘analyses’ it. If this low voltage signal is within specification, the BCM allows your car to start. Well, sometime this signal gets lost somehow or is not within specification because of burnt contactor(s) inside the ignition switch.
What you can do is install a permanent resistor on the yellow wire in your ignition to trick the BCM. If done correctly your car should start every time after that. Okay now, let me be honest here: I've never done this myself, so if you decide to try this, I cannot garantee that it will work; but I've been reading many posts about this, and it appears to be workign for everyone who tried it... your call.
Check the following links; it is a discussion about this intermittent no start problem and that fix I'm talking about:
http://www.automotiveforums.com/vbulletin/showthread.php?t=731311
http://www.automotiveforums.com/vbulletin/showthread.php?t=698861&highlight=passlock+bypass
Hope this help
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Saab
Saturn
Scion
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2009 2CarPros.com - Professional Mechanics Online
