Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Shakes or Wobbles problem
2000 Chevy Express V8 Two Wheel Drive Automatic 114785 miles
AT 45 TO 50 MPH I LET OF THE GAS AND SLOWLY PUT MY FOOT BACK ON THE GAS IT KICKS AND FILLS LIKE IT SKIPPING UNTIL I GO HEAVY ON THE GAS . IT ONLY DOSE THIS WHEN ITS GOING TO OVERDRIVE , IF I'AM OVERDRIVE AT AROUND 60 PLUS MPH IT DOSE NOY DO IT WHAT COULD CAUSE THIS ?
It could be overdrive clutch chatter or the lockup torque convertor. If you have access to a scan unit, you can monitor when your transmission is shifting and what gear you are in, or going into, when the shudder occurs. This will help narrow it down.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
