Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Cooling problem
2000 Chevy Camaro 6 cyl Two Wheel Drive Automatic 128117 miles
Cooltant poured onto street after cut-off. Notice rust inside of cooltant intake(where you pour in coolant) nor running hot just bought it last night. Is this a major problem?
Something causing it to boilover-Get it block and pressure tested-could be headgasket/cracked head/block-water pump, clogged radiator-thermostat-air lock
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
