Suspension problem
2000 Cadillac Deville V8 Front Wheel Drive Automatic 63000 miles
when i purchased this auto used in 2001 the rear end was high,i called dealer she told me i could lower same by adjusting air line they did,and have had no problem, however it recently dropped and getting a very bumpy ride mech checked and found the elc relay was missing thinks maybe the pump could of failed and dealer remove the relay and manually raised the rear end, if this is true could i do same and how also if i should need a new pump for that system,how much would it cost to replace.thank you.
