Welcome to our question and answer forum. We answer over
6,000 free and donated auto repair questions every
month. All you have to do to ask a question is to signup
to our forum.
Asking a question is free of charge and your question
will be answered by one of our non-certified forum users
for free. You can however elect to donate to make sure
your question gets an guaranteed and professional answer
by one of our many 2carpros certified repair
technicians.
Questions
with donations are answered as promptly as possible.
Due to the nature of car repair problems, some take
longer to solve than others. We are confident that you
will be better informed regarding your problem and will
have an good idea of what direction your repair needs to
go after we have answered it. If you have donated and
were unsatisfied with our effort we will gladly return
your donation. We help thousands of people every month
and want to help you too. Sometimes it requires some
dialog between our technicians and you to get to the
bottom of your problem. 100% of the
donation is awarded to the technicians helping you.
Electrical problem
2000 Buick Century 6 cyl Front Wheel Drive Automatic 80000 miles
What could be causing the starter to drag..the battery checks out to be good.. alt cks out to be good as well....belt tension is at proper tension too!
Electrical problem
How did you check the battery? If you just check it with an ohm meter - that only tells you what the battery charge is. It could show 12v or more and you can still have the drag.... Why? because the Cranking Amps may not be up to par. If you had all that checked the next thing to do is to check your Battery Ground Wire make sure it is clean and has good contact.
Lastly it could be a bad starter. If you take it off most auto parts store can Bench Test them.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
