Shakes or Wobbles problem
2000 BMW Z3 6 cyl Two Wheel Drive Manual 64,000 miles
once in a while while at a complete stop at a lite or stop sign with the break applied and the cluth all the way to the floor i can feel a quick pulsing in the cluth pedal. if i lift the pedal off the floor an inch or so the pulsing goes away.
any idea what may be causing this to happen ?
Find a
repair manual for your BMW Z3 Repair Question.
Posted at Tue Mar 04, 2008 6:06 pm
By
Advertisment,
Find a
This can be caused by a defective clutch pressure plate, the fingers on the clutch pressure plate are not depressing equally and the thrust bearing is vibrating slightly causing the pulsation effect.
Mark (mhpautos)
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
