Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Computer problem
2000 BMW X5 V8 All Wheel Drive Automatic 109,42 miles
i have 3 codes that pop up on my scanner 0171,0173,1340
2 of them are fuel trim
the other says misfire malfunction during start up. i do have a small coolant leak that will be repaired on mon. what can cause the fuel trim problem and the misfire malfunction. the car seems to run good,a little harder on gas than usual.thanx
Do you know where the coolant leak is coming from? The higher mileage M-62 motors can have a significant repair expense for certain failures. A PCV plate and intake reseal may be needed to remedy the fuel trim faults, and perhaps replacement of both the pre-cat oxygen sensors, then reset the adaptations and drive to complete readiness monitors.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
