Car Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
2000 BMW 530 Car wont start
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Thu May 08, 2008 1:14 pm |
By
jwetherill,
Likes cars! |
Give Feedback | Votes: 0 |
Engine Mechanical problem
2000 BMW 530 6 cyl Two Wheel Drive Automatic 105000 miles
Hi, I went to the supermarket and all was fine then when I got back to the car the battery was completely dead. I jumped it off then charged the battery back at home but then I could not start the car even with jump leads.
I thought the battery was duff (and it was) so replaced it but the car still will not start - it turns over and tries to start but it just will not fire. All other electrics seem to be ok and fuel is being supplied from the pump.
Would the flat battery have tripped something out that I cannot see? e.g do I need to reset anything on the computer or do you think there is something else wrong - it seems too much of a coincidence that the battery went flat and suddenly I cannot start the car.
Any help appreciated.
| Find a
car repair manual for your BMW 530 Repair Question. |
By
Advertisment,
| Find a
Posted at Fri May 09, 2008 12:23 am |
By
jwetherill,
Likes cars! |
Thanks, I will try the suggestions and I won't jump start again.
| Find a
Posted at Sat May 10, 2008 5:47 am |
By
jwetherill,
Likes cars! |
Fuel and spark are present.
| Find a
Posted at Sat May 10, 2008 12:34 pm |
By
jwetherill,
Likes cars! |
I removed the spark plug leads one by one and ground it to the engine bay which sparked.
The fuel - I undid the small bleed screw near the injectors whilst someone cranked the engine and pushed the nipple down and it sprayed out, when the engine was not cranking it did not spray out so I presume it must be suppying the fuel - is this a correct assumption (My experience is limited).
Thanks for your replies
| Find a
Posted at Wed May 14, 2008 6:26 am |
By
jwetherill,
Likes cars! |
I did not try the noid light, instead I decided to get a local garage to put it on their diagnostics, they say that there are no error codes coming back and they are stumped as to what the problem might be.
All they can suggest is that I take it to BMW.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
