Transmission problem
2000 BMW 328 6 cyl Two Wheel Drive Manual 90000 miles
there is a clunk noise in rear when shifting between gears like something in rear is lose but i i dont see anything but there is more(side to side! only) play in rt axel than lt. also there is a groan sound under accelaration like bad tire but not. hope there is not bad bearings in rear??
have any thoughts?
There was a bulletin for this. the center support bearing might be making the noise and the repair involves using an isolator made of mastic between the bearing and the body mount. It may also be a bearing, but it is difficult to diagnose noises from cyberspace.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
