Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair & Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Discount Auto Parts
Vehicle Repair Online Repair Manual
Vehicle Repair Car Maintenance
Vehicle Repair Car Safety Information
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Forum Topics
Auto Repair1993 Honda Civic
Auto Repair1997 Vauxhall Astra Brak...
Auto Repair2005 Dodge Neon Check En...
Auto Repair1988 Chevy Cheyenne Firi...
Auto Repair1998 Jeep Cherokee Probl...
Auto Repair2001 Mitsubishi Galant D...
Auto Repair1993 Buick Skylark Stalling
Auto Repair2006 Nissan Altima Indic...
Auto Repair2004 Acura Tl Ac Stopped...
Auto Repair2001 Nissan Pathfinder Re...
Auto Repair1993 Ford Explorer Lights
Auto Repair1990 Geo Storm Timing Belt
Auto Repair2001 Ford Focus Leaky/ba...
Auto Repair1990 Dodge Ram Heater Core
Auto Repair1979 Chevy Van Reverse S...
Auto RepairMore Forum Topics...
Locate Auto Parts
Latest How-To Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Automotive Repair Forum
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 BMW 323 head bolt threads stripping
Posted at Tue Dec 04, 2007 2:23 pm
By larry forkner, Have Donated
Give Feedback | Votes: 0
Engine problem
2000 BMW 323 Two Wheel Drive Automatic 100000 miles
This is the first BMW engine I've worked on and first question asked on the computer so here goes. The car overheated so I took it down for inspection. Three very clean cylinders and a thin head gasket was all I found. We had the head milled .007 in. The block and bolt hole were clean.I used a standard thickness head gasket and new head bolts. I torqued them to 40NM with a quality torqe wrench.I used a beam type torqe wrench to watch as I Turn the 90 degree turns. On the first bolt in the pattern, at the start of the second 90 turn,(about 65 ft/lbs) the threads turned loose. I trying to decide: Do Heli-coil all 14 bolt holes.Do I use another set of bolts( they are still obviously shorter than the oringinal), Should I use the .3mm thicker head gasket. Any advise would be greatly appreciated
Find a repair manual for your BMW 323 Repair Question.
Posted at Tue Dec 04, 2007 4:38 pm
By Dr. Hagerty, Moderator
Reputation: 102.7Reputation: 102.7Reputation: 102.7Reputation: 102.7Reputation: 102.7 (103) Give Feedback | Votes: 6
BMW recommends replacement of the block if the threads pull out. Helicoils are a possibility, I have personally never trusted them for high load areas. If you milled the head .007" you may have exceeded the amount of material the head can be machined, the minimum head thickness is 139.7mm. The heads on the M-52 motors are prone to cracking, be sure to pressure test. What is obviously shorter?
Make a small donation! (We will make sure your question will be answered promptly)
Reply to topic
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins.Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
Computer Repair
