Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1997 Pontiac Grand Prix
Auto Repair1989 Honda Civic Engine...
Auto Repair2001 Ford Taurus Rubbin...
Auto Repair2002 Pontiac Sunfire Ca...
Auto Repair2000 Chevy Malibu Engin...
Auto Repair1999 Honda Accord Alarm
Auto Repair1984 Pontiac Firebird M...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Audi S4 Question Timing Belt Replacement
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Mar 13, 2008 6:55 am
By mfaski, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
2000 Audi S4 Question 6 cyl Four Wheel Drive Manual 75000 miles
I am in the process of replacing the timing belt and have the Audi factory manual. It instructs you to
Position the engine at TDC
Install locking pin 3242
Remove vibration damper on crankshaft
Remove idler wheel for toothed belt
I am ok up to hear but this part does not make sense
Compress the toothed belt tensioner and insert tool
T40011 and then remove the toothed belt
Insert camshaft clamp 3391 in securing plates of
two camshafts
Slacken both camshaft bolts and remove
approximately 5 turns
TAKE OUT camp 3391
Pull off both camshaft sprockets
Reinstall both camshaft sprockets and the securing
plate and tighten hand tight (so they can
rotate on the taper shaft but not move axially)
Install new toothed belt
Install camshaft clamp 3391
Remove special tool T40011 from tensioner
What is confusing me is that once release the tension on the belt and remove it what is preventing the cam shafts from rotating in relationship to each other and the crank!
I understand that the clamp 3391 will hold the cam sprockets in alignment but they are seated on a tapered shaft ie not keyed.
It seems to me that value springs could very easily move the cams and screw up the timing.
Am I missing something??
Find diagnostic tools, replacement parts or locate a car repair manual for your Audi S4 Question.
By Advertisment,
Posted at Thu Mar 13, 2008 12:42 pm
By 2CarPro Jack, Certified ASE Technician
Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3Reputation: 639.3 (639) Give Feedback | Votes: 80
My instructions say nothing about loosening the cam gear bolts. I would mark everything (nailpolish, paint pen) with the crank on TDC. Use a cam holding tool between the two cam gears to hold them in time before loosening the timing belt tensioner.If the cams are held together, they wont move out of time from the crank.Unload tensioner and pin it in place, remove the belt and replace it with new, retension and verify all marks are lined up.If the belt runs the water pump, replace it as well or it will leak within 1 month
Posted at Thu Mar 13, 2008 1:19 pm
Jack
I did some more digging and found out that the cam shafts have a "Flat" machined on the end of them and that the cam securing plates have a "D" shape Inside Diameter that fits over the end of the shaft. When the camshaft clamp tool 3391 is used it aligns the cam shaft in the correct orientation with respect to the crank at TDC. According to the Audi Manual you need to lossen the cam sproket retaining bolts and pull them off the tapored shaft in order to ensure that the new belt is tensioned properly prior to the cam sprockets being pressed back onto the tapored shaft. If this is not done they is a possibility that the span of the belt from 12:00 o'cllock on the left sprocket to 12:00 oclock on the right sprocket will be loose. If this occures the value cam will move relative to the crank at TDC when the securing plate is removed.
I can show you some pictures if this does not make sense.
Posted at Thu Mar 13, 2008 1:33 pm
Makes sense in Audis world.....lol every other car uses an auto tensioner to do this. Over engineering to say the least.So what is your question?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
