one, make sure that the fan is on when the a/c is on /always. two it sounds like you may have a leak, since the compressor is cylcling so often/but it could also be the high pressure switch, gone bad. and then the mildew could be the build up of leaves and debris on your evaporator core, that would need to be cleaned out. its several things that could be going on. There are several places that will do a free,
A/C check up and tell you exactly whats wrong. those are all possibilities that I ran down to you.
