Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1984 Other Subaru Models...
Auto Repair2003 Buick Rendezvous B...
Auto Repair1986 Chevy Silverado Ne...
Auto Repair2001 Jeep Laredo Brake ...
Auto Repair2002 Ford Escape Car Qu...
Auto Repair1988 Ford Bronco Thermo...
Auto Repair1988 Chrysler 5th Avenue...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
2000 Acura TL 2000 TL Overheating
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Aug 25, 2008 5:18 pm
By hocki, New to the forum
Give Feedback | Votes: 0
Engine Cooling problem
2000 Acura TL 6 cyl Front Wheel Drive Automatic 248000 miles
I have a high mileage TL that normally runs very cool. Lately, I have noticed issues with the heater... it seems to be blowing humid air... which fogs up the windshield... the A/C is not working, and when driving up hill slowly, the car is overheating. Flat ground the temp gauge is at the halfway point (hot for this car)... with the AC fan circulating, the car is marginally fine. (minus any slow climbs)
The A/C fan comes on but not the other radiator fan... we have swapped the relay... a mechanic said it was not the thermostat, and recently replaced the Timer/Fan/Heater Control chip. The waterpump was replaced in November with the timing belt. (not sure about the thermostat)
The fan, when plugged into the A/C fan plug, works perfectly.
Any thoughts on what this could be? I'm $200.00 into repairs on this issue, and nothing to show for it... Any help you can send me would be greatly appreciated.
Find a car repair manual for your Acura TL Repair Question.
Posted at Sat Aug 30, 2008 5:04 am
By KHLow2008, Moderator
Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2Reputation: 179.2 (179) Give Feedback | Votes: 13
Hi hocki,
Are you losing coolant from the system? Check radiator coolant level. The heater core might be leaking.
Both fans should work in tandem. Check if power is present at radiator fan relay, 1 terminal shuld be hot at all times while another will get power when ignition switch is turned on.
Does bridging the relay terminals for the fans works? If power is present and bridging does not work, you need to check for open circuit from relay to fan motor. Relay terminals tends to heat up and cause bad connections.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
