first, any blinking green key lights on the dash? just want to make sure you are using a programmed key.
sit next to the pump and have someone turn the ignition on but not start.you should hear a 2 second hum whenever the key is cycled. that means your pump is working. if not... check fuse 22 under the dash, then check the fuel pump relay in the trunk;black and on the driver side of the fuel pump.
then check the fuel lines, start at the fuel rail and work your way back to the pump.
