Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2003 Ford Focus Engine O...
Auto Repair1993 Nissan Maxima I Can...
Auto Repair1994 Ford Thunderbird Ti...
Auto Repair2002 Buick Lesabre Chang...
Auto Repair1996 Chevy Lumina Vacuum...
Auto Repair2003 Volvo S60 Message B...
Auto Repair2003 Subaru Outback Tran...
Auto Repair1996 Chevy Tahoe Turning...
Auto Repair1988 Toyota Corolla Mech...
Auto Repair2001 Nissan Maxima Blowe...
Auto Repair1991 Jeep Laredo Engine ...
Auto Repair1999 Chrysler Sebring Po...
Auto Repair1988 Bmw 535 Horn By The...
Auto Repair1990 Mercury Marquis Oil...
Auto Repair2003 Ford Taurus Water
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Volkswagen Jetta radiator and AC cooling
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri May 16, 2008 9:26 pm
By beachebabe, New to the forum
Give Feedback | Votes: 0
Engine Cooling problem
1999 Volkswagen Jetta 6 cyl Two Wheel Drive Automatic 90000 miles
how do i replace the radiator in a 1999 VW Jetta VR6?
Find a repair manual for your Volkswagen Jetta Repair Question.
By Advertisment,
Posted at Fri May 16, 2008 9:58 pm
By legitimate007, Moderator
Reputation: 134.7Reputation: 134.7Reputation: 134.7Reputation: 134.7Reputation: 134.7Reputation: 134.7Reputation: 134.7 (135) Give Feedback | Votes: 6
Radiator, removing and installing
Fig. 128: Identifying Special Tools - Radiator, Removing And Installing
Courtesy of VOLKSWAGEN UNITED STATES, INC.
Special tools, testers and auxiliary items required
Drip pan VAG 1306 for Shop crane VAG 1202 A
Torque wrench (5-50 Nm) or equivalent VAG 1331 or equivalent
Hose clip pliers VAG 1921
Hydrometer
Main radiator
Auxiliary radiator
Removing
Drain coolant, refer to Coolant, draining and filling .
Remove front bumper: Refer to FRONT BUMPER
Pull quick-coupler off radiator.
Disconnect connectors from thermal switch and coolant fans.
Place lock carrier into service position: Refer to LOCK CARRIER SERVICE POSITION
Remove radiator retaining screws and remove radiator and fan from below.
NOTE: For vehicles with air conditioning.
Installing
Installation is in reverse order, but note the following:
Fill with coolant, refer to Coolant, draining and filling .
Notes and assembly procedures for vehicles with air conditioning
CAUTION: Do not open the A/C refrigerant circuit.
NOTE: To prevent damage to the condenser, refrigerant lines and hoses, be careful that the lines and hoses are not overstretched, creased or bent.
Unscrew retention strap(s) on refrigerant lines.
Remove condenser from radiator and fasten to lock carrier.
Auxiliary radiator
Removing
Remove right front sound-proofing mat: Refer to NOISE INSULATION (GASOLINE ENGINES), ASSEMBLY OVERVIEW or NOISE INSULATION (DIESEL ENGINES), ASSEMBLY OVERVIEW
Remove fender liner, front right: Refer to 66 EXTERIOR EQUIPMENT
Remove front right air outlet: Refer to 63 BUMPER
Remove windshield washer reservoir: Refer to 92 WINDSHIELD WIPER & WASHER SYSTEM
Fig. 129: Locating Coolant Hoses At Auxiliary Radiator In Engine Compartment Below Right Headlight
Using pliers for spring band clips ( Hose Clip Pliers VAG 1921 ), pull coolant hoses off auxiliary radiator in engine compartment below right headlight - arrows -.
Fig. 130: Locating Coolant Hoses At Auxiliary Radiator In Engine Compartment Below Right Headlight
Remove upper retaining screws - 1 - of auxiliary cooler.
Remove lower retaining screws in front wheel housing from bracket.
Carefully remove auxiliary radiator with its attachments from below.
Installing
Installation is in reverse sequence, but observe the following directions:
Fill with coolant refer to Coolant, draining and filling .
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
