Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1999 Buick Park Avenue ...
Auto Repair1989 Ford F150 Inconsis...
Auto Repair2001 Pontiac Grand Prix ...
Auto Repair1995 Nissan Maxima Hard...
Auto Repair1992 Dodge Colt Fuel Pu...
Auto Repair1993 Ford Taurus Coolan...
Auto Repair2000 Daewoo Nubira Cran...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1999 Toyota Sienna P,R,N,D etc.
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Tue Jul 22, 2008 9:50 am
By mmendez333, Have Donated
Give Feedback | Votes: 0
Steering problem
1999 Toyota Sienna 6 cyl Two Wheel Drive Automatic 119000 miles
When I grab the selector lever to change from Parking (P) to Drive (D) or Reverse (R), is really hard to move it down it kinda gets stuck. Then when I move it up to the Parking (P) to park is still hard and the light where it tells me on what letter I have it dissapears, if I let the brake go the van goes back and the light comes back on but on Reverse (R) not where I put it on (P). I have to move the selector lever up and down in order to let it stay on (P) with the light on and not on reverse. If I keep doing that am I messing up something on the van, like the transmission or something? How can I fix it? Thank you
Find a car repair manual for your Toyota Sienna Repair Question.
Posted at Tue Jul 22, 2008 12:22 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
SHIFT INTERLOCK SYSTEMS -1999 Toyota Sienna LE
Page 1 of 9
ARTICLE BEGINNING
DESCRIPTION
Transmission/transaxle is equipped with a electronically controlled shift lock and key lock system. See Fig. 1 . Shift lock system prevents shift lever from being moved from Park unless brake pedal is depressed. In case of a malfunction, shift lever can be released by depressing shift lock override button, located near shift lever. Key lock system prevents ignition key from being moved from ACC to LOCK position on ignition switch unless shift lever is in Park.
System consists of brakelight switch, key interlock solenoid, shift lock control switch, shift lock control Electronic Control Unit (ECU), shift lock solenoid and shift lock release button. All models may not be equipped with all components. See Fig. 1 .
NOTE: Sienna is equipped with cable operated shift lock system. See CABLE OPERATED SHIFT LOCK SYSTEM CHECK and ADJUSTMENTS .
Fig. 1: Shift & Key Lock System Component Locations (Typical)
Courtesy of TOYOTA MOTOR SALES, U.S.A., INC.
OPERATION
SHIFT LOCK SYSTEM
With ignition on, when brake pedal is depressed, an input signal is sent from brakelight switch to ECU. With shift lever in Park, an input signal from shift control switch is input to ECU, indicating shift lever is in Park. ECU then operates shift lock solenoid, so shift lever can be moved from Park.
KEY LOCK SYSTEM
With ignition in ON or ACC position and shift lever in Park, shift lock control switch opens and voltage from ECU to key interlock solenoid is turned off. When key interlock solenoid is turned off, ignition key can be turned from ACC to LOCK position on ignition switch.
COMPONENT TESTS
NOTE: If ignition is left in ACC or ON position with shift lever in any gear range except Park for about one hour, ECU then operates to release lock mechanism.
ELECTRONIC CONTROL UNIT (ECU)
Access ECU. See Fig. 1 . ECU is under center console, in front or back of shifter. Turn ignition on. Backprobing ECU harness connector with DVOM, check voltage between designated terminals.
http://www.ondemand5.com/mric/common/asp/printart.aspx
7/22/2008
Page 2 of 9
Voltage should be as specified. See appropriate SHIFT LOCK SYSTEM PIN VOLTAGES table. For circuit identification, see appropriate wiring diagram in WIRING DIAGRAMS .
NOTE: Ground (GND) terminal is also referred to as "E" terminal.
SHIFT LOCK SYSTEM PIN VOLTAGES (AVALON, CAMRY, CAMRY SOLARA, COROLLA, ES300 & RX300)
Application & Terminals Description Voltage ECU ACC - GND Ignition Switch In ACC Position IG - GND Ignition Switch In ON Position STP - GND Depress Brake Pedal 10-14 KLS - GND Ignition Switch In ACC, Shifter In "P" Position KLS - GND Ignition Switch In ACC, Shifter Not In "P" Position KLS - GND (1) Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Solenoid SLS+ - GND Ignition Switch In ACC, Shifter In "P" Position SLS+ - GND Depress Brake Pedal 8-13.5 SLS+ - GND Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Control Switch P1 - P Ignition Switch ON, Shifter In "P" Position, Depress Brake Pedal P1 - P Ignition Switch In ON, Shifter Not In "P" Position P2 - P Ignition Switch In ACC, Shifter In "P" Position 9-13.5 10-14 0 6-9 0 9-13.5 10-14 0 7.5-11.5 0
(1) Voltage measurement after one second.
SHIFT LOCK SYSTEM PIN VOLTAGES (CELICA, LAND CRUISER, LX470 & TACOMA)
Application & Terminals Description Voltage ECU ACC - GND Ignition Switch In ACC Position IG - GND Ignition Switch In ON Position 10-14 10-14
7/22/2008
Page 3 of 9
STP - GND KLS - GND
KLS - GND
KLS - GND
Shift Lock Solenoid SLS+ - SLS- Ignition Switch In ACC, Shifter In "P" Position 0 SLS+ - SLS- Depress Brake Pedal 8-13.5 SLS+ - SLS- Depress Brake Pedal, (After 20 Seconds) SLS+ - SLS- Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Control Switch P1 - P Ignition Switch In ON Position, Shifter In "P" Position, Depress Brake Pedal P1 - P Ignition Switch In ON, Shifter Not In "P" Position 9-13.5 P2 - P Ignition Switch In ACC, Shifter In "P" Position P2 - P Ignition Switch In ACC, Shifter Not In "P" Position 5.5-9.5 0 0 0 9-13.5
Depress Brake Pedal 10-14 Ignition Switch In ACC, Shifter In "P" Position Ignition Switch In ACC, Shifter Not In "P" Position 6-9 0 10-14 (1) Ignition Switch In ACC, Shifter Not In "P" Position
SHIFT LOCK SYSTEM PIN VOLTAGES (GS300 & GS400)
Application & Terminals Description Voltage ECU ACC - GND Ignition Switch In ACC Position 10-14 ACC - GND Ignition Switch In ON Position KLS - GND Ignition Switch In ACC, Shifter In "P" Position KLS - GND (1) Ignition Switch In ACC, Shifter Not In "P" Position SLS+ - GND Ignition Switch In ON, Shifter In "P" Position SLS+ - GND Ignition Switch In ON, Depress Brake Pedal 10-14 6-9 3-6 0 0
7/22/2008
Page 4 of 9
SLS+ - GND
SLS+ - GND
P1 - GND P1 - GND
Ignition Switch In ON, Release Brake Pedal Ignition Switch In ACC, Shifter Not In "P" Position Shifter In "P" Position 0 Shifter Not In "P" Position 10-14 0 3-6
SHIFT LOCK SYSTEM PIN VOLTAGES (LS400)
Application & Terminals Description Voltage ECU ACC - GND Ignition Switch In ACC Position 10-14 IG - GND Ignition Switch In ON Position STP - GND Depress Brake Pedal 10-14 KLS - GND Ignition Switch In ACC, Shifter In "P" Position KLS - GND Ignition Switch In ACC, Shifter Not In "P" Position KLS - GND (1) Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Solenoid SLS+ - SLS- Ignition Switch In ACC, Shifter In "P" Position SLS+ - SLS- Depress Brake Pedal 8.8-12.5 SLS+ - SLS- Depress Brake Pedal, (After 20 Seconds) SLS+ - SLS- Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Control Switch P1 - P Ignition Switch In ON Position, Shifter In "P" Position, Depress Brake Pedal P1 - P Ignition Switch In ON, Shifter Not In "P" Position P2 - P Ignition Switch In ACC, Shifter In "P" Position P2 - P Ignition Switch In ACC, Shifter Not In "P" Position 10-14 8.5-10.5 0 0 10-14 0 1.5 Or Less 6.5-9.2 10-14 7-8.5 0
7/22/2008
Page 5 of 9
SHIFT LOCK SYSTEM PIN VOLTAGES (RAV4)
Application & Terminals Description Voltage ECU ACC - GND Ignition Switch In ACC Position IG - GND Ignition Switch In ON Position STP - GND Depress Brake Pedal 10-14 KLS - GND Ignition Switch In ACC, Shifter In "P" Position KLS - GND Ignition Switch In ACC, Shifter Not In "P" Position KLS - GND (1) Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Solenoid SLS+ - GND Ignition Switch In ACC, Shifter In "P" Position SLS+ - GND Depress Brake Pedal 8-14 SLS+ - GND Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Control Switch P1 - P Ignition Switch In ON Position, Shifter In "P" Position, Depress Brake Pedal P1 - P Ignition Switch In ON, Shifter Not In "P" Position P2 - P Ignition Switch In ACC, Shifter In "P" Position 10-14 0 6-8.5 0 10-14 10-14 0 10-14 8-13.5 0
SHIFT LOCK SYSTEM PIN VOLTAGES (SC300 & SC400)
Application & Terminals Description Voltage ECU ACC - GND Ignition Switch In ACC Position IG - GND Ignition Switch In ON Position STP - GND Depress Brake Pedal 10-14 KLS - GND Ignition Switch In ACC, Shifter In "P" Position 10-14 1.5 Or Less 10-14
7/22/2008
Page 6 of 9
KLS - GND
8.5-10.5
6.5-8.5
Shift Lock Solenoid SLS+ - SLS- Ignition Switch In ACC, Shifter In "P" Position 0 SLS+ - SLS- Depress Brake Pedal 8.0-12.5 SLS+ - SLS- Depress Brake Pedal, (After 20 Seconds) 6.5-9.2 SLS+ - SLS- Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Control Switch P1 - P Ignition Switch In ON Position, Shifter In "P" Position, Depress Brake Pedal P1 - P Ignition Switch In ON, Shifter Not In "P" Position 10-14 P2 - P Ignition Switch In ACC, Shifter In "P" Position P2 - P Ignition Switch In ACC, Shifter Not In "P" Position 0 10-14 0 0
KLS - GND
SHIFT LOCK SYSTEM PIN VOLTAGES (4RUNNER)
Application & Terminals Description Voltage ECU ACC - GND Ignition Switch In ACC Position 10-14 IG - GND Ignition Switch In ON Position STP - GND Depress Brake Pedal 10-14 KLS - GND Ignition Switch In ACC, Shifter In "P" Position KLS - GND Ignition Switch In ACC, Shifter Not In "P" Position KLS - GND (1) Ignition Switch In ACC, Shifter Not In "P" Position Shift Lock Solenoid SLS+ - SLS- Ignition Switch In ACC, Shifter In "P" Position SLS+ - SLS- Depress Brake Pedal 8-13.5 10-14 7.5-11 0 0 6-9.5
7/22/2008
Page 7 of 9
SLS+ - SLS-
SLS+ - SLS-
Depress Brake Pedal (After 20 Seconds) Ignition Switch In ACC, Shifter Not In "P" Position
6-8.5
0
0
9-13.5
9-13.5
0
SHIFT LOCK SOLENOID
1.Disconnect electrical connector from shift lock solenoid. Using ohmmeter, measure resistance between shift lock solenoid terminals. See WIRING DIAGRAMS . 2.Replace shift lock solenoid if resistance is not within specification. See SHIFT LOCK SOLENOID RESISTANCE SPECIFICATIONS table. Apply battery voltage between shift lock solenoid terminals. Replace shift lock solenoid if operating sound cannot be heard.
SHIFT LOCK SOLENOID RESISTANCE SPECIFICATIONS Application Ohms Avalon, Camry, Camry Solara & Tacoma (A43D) 30-35 Celica, Corolla, GS300, GS400 & 4Runner 21-27 ES300 & RX300 29-36 Land Cruiser, LS400, LX470, SC300, SC400 & Tacoma (A-340E/F) 20-28 RAV4 26-33
KEY INTERLOCK SOLENOID
1.Disconnect electrical connector from key interlock solenoid. Using ohmmeter, measure resistance between key interlock solenoid terminals. See WIRING DIAGRAMS . 2.Replace key interlock solenoid if resistance is not 12-17 ohms. Apply battery voltage between of key interlock solenoid terminals. Replace key interlock solenoid if operating sound cannot be heard.
SHIFT LOCK CONTROL SWITCH
Disconnect electrical connector from shift lock control switch. Using ohmmeter, check continuity between specified terminals in relation to shift lever. See WIRING DIAGRAMS . See SHIFT
7/22/2008
Page 8 of 9
LOCK CONTROL SWITCH CONTINUITY table. Replace switch if continuity is not as
specified.
NOTE: Continuity must be checked in accordance with position of release button on shift lever and shift lever position.
SHIFT LOCK CONTROL SWITCH CONTINUITY
Shift Lever Position & Condition Any Other Gear Except Park Park & Release Button Not Pushed Park & Release Button Is Pushed
Terminals P & P2 P & P1 P & P1 Or P & P2
Sienna
Ensure shift lock cable does not interfere with wiring harness. Ensure ignition switch turns to LOCK position when shift lever is in "P" position. Ensure brake pedal returns fully. Ensure shift lock is released when brake pedal is depressed with ignition switch at ACC, ON or START position.
ADJUSTMENTS
PARKING LOCK CABLE
Sienna
Place shift lever in "P" position. Turn ignition switch to LOCK position. Loosen 2 bolts and ensure pedal button touches pedal plate cushion. Tighten 2 bolts to 97 INCH lbs. (11 N.m).
Posted at Tue Aug 12, 2008 12:02 pm
Thanks for the reply but it did not help me much and the picure (diagram) is not where the lever selector of my sienna is. But thank s anyway....
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
