Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Brakes problem
1999 Toyota Landcruiser V8 All Wheel Drive Automatic 93,000 miles
When I apply the brakes the vehicle shakes and wobbles very violently along with the brakes pedal. The rotors and brakes are new. What do you think might be the problem?
Thank you,
Corey
Find a car repair manual for your Toyota Landcruiser Repair Question.
could be tie rod ends, rotors could be warped, calipers may be loose, ball joints could be bad, all of these could be a possible culprit,or even a combination of them, the only way to know is to inspect the front suspenstion along with the calipers and rotors
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
