Hello –
Did you check what Mr Weizel suggested?
Okay, so we get on the same page here…….I think the manual is a little confusing and we are saying different things but thinking we are saying the same thing………see what you think….gee, even my explanation is confusing…….
When you said the hi beams only do not work – as you see by the troubleshooting chart below, there are several things – even head lamps work tail lights no. You might check your tail lights though…..do all of these checks to make sure it is really “just” the high beams.
When you look at the red arrow – that is hi beams only do not work. I understand that to mean low does. So your low beams do work if I understand you.
Okay, as you see the first thing it says is probably the Headlight Dimmer Switch. This is where it gets going…..so hold on. You said you replaced the dimmer switch. Below is the pic of the “dimmer switch” in the manual. Probably not what you replaced I am sure.
Now it says to go to the Light Control Switch, which I gave you…..but this is actually what you replaced….right?
Okay, this is a two part switch….I have attached these. They have different checks as you see. The headlight dimmer switch is part of the light control switch…..the light control switch has different check.
I know – well I think I know you replaced this entire switch which should be both of them. But would you please do the separate checks to see how if it works and let me know.
Next, I have provided the test for the Head lamp relay
The test for the dimmer relay
The test for the daylight relay
The location of all to include the two fuses for Rt and Lt headlamps.
Try this out and see what you think.
Thanks for the donation
Please let us know if what the final fix was for your car so we can better assist others. Thanks!
Find a car repair manual for your car repair questions.
